-   -   Pressure/Force on Wall BCP (http://www.cfd-online.com/Forums/cfx/21896-pressure-force-wall-bcp.html)
Gabor December 2, 2005 09:47
Hello CFX-experts,
I have a problem about exporting the nodal force/pressure values affected by a fluid on a wall BCP.
There are the two routines "user_getvar" and "user_get_gvar", but how do I have to initialize those routines, to get a table with the values of the forces/pressures on each node of my BCP?
Thanks for you help,
Gabor
Chirag Jayswal December 3, 2005 03:17
Re: Pressure/Force on Wall BCP
In CFX-Post you can export force / pressure affected by a fluid on wall using following path.
- Open File Menu > Export. - Choose the path where you want to save exported file. Also write desired file name with an extension of ".csv". - Now in "Locactions" option, select the surface on which you want to find out the Force / pressure acting on to. - Tick on Node Numbers. - Select variable as force or pressure. - Click on "Save".
Open this *.csv file in MS Excel. You will find value of force / pressure for each node of specified surface. Done.
Gabor December 5, 2005 11:06
Thank you for that very helpful information.
But is there also a way to get those nodal force-values inside a user_fortran routine? I am programming a fluid-strucute-interaction algorithm using CFX and therefore I need those values inside a calculation run, because the force-values are influencing my mesh motion, and the mesh-motion is influencing the new force-values.
Thank you for the help.
Gabor
