naca 12 error
Old   January 18, 2006, 13:43
Default naca 12 error
Conor
Hi I'm trying to preform a simple calibration test on CFX10 to run a range of angles of attack for a NACA 12 foil at a Reynolds number of 600,000 and compare my results with official NACA data.
I've set my NACA foil up very similar to the boundary conditions and other settings used in the tutorial WingSPS only changing the setting supersonic to subsonic and obviously reducing my velocity to about 92m/s. I'm also using tetra mesh with a fine layer of prisim mesh around the foil.
I've tried a million different mesh desities and tried many different turbulent intensity values and turbulent length scale values with very little difference between each in my results. My Y+ value is well under 1 all over the entire foil. For an angle of 8 degrees my error is still a massive 10 percent for lift and off the chart for drag. I think I'm doing something seriously wrong. I would really appreciate any help you might be able to previde????
Conor
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
