Home > Forums > CFX
injection into foam
Old   December 15, 2005, 23:33
Default injection into foam
jemteo
Need some advice:
i want to visualize the flow path of water through foam ( of different porosity) from a syringe and needle. the needle is inserted randomly into foam. i do not want to model the needle into the foam. some questions which i have
(1) is it a steady state or transient simulation? (2) how do i set an inlet in the middle of the foam? (3) how do i visualize is such that it is like a mold filling animation?
thanks so much in advance.
Old   December 16, 2005, 08:18
Default Re: injection into foam
Rui
(1): You have answered this with your question (3) (2): You may create a thin subdomain and set a source of water (3): You may define an isosurface of water volume fraction = 0.5 , or an isovolume of water volume fraction >= 0.5 . The tutorails show how to create animations.
Regards,
Rui
Old   December 17, 2005, 00:12
jemteo
Rui should i be using a muliphase flow? having air and water as my fluids?
Old   December 17, 2005, 03:57
jemteo
rui,
still not sure if it should be a transient or steady flow simulation.
basically i'll need to see how the water flows thru the porous foam after certain time. i could use a physical timescale with steady state? i followed Tutorial15 of CFX on multiphase modeling as a test.
can i use transient? any tutorial to recommend for this?
txs
Old   December 17, 2005, 04:20
jemteo
sorry found this after posting http://www.cfd-online.com/Forum/cfx_...cgi?read=11391
for those interested.
Thread Tools
Trackbacks are On
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
Import problem ARC Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 February 27, 2010 11:56
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
