January 10, 2006, 09:02 |
CFX 10-STRUCTURED MESH
Does CFX 10.0 accept structured mesh ?
January 10, 2006, 09:05 |
Re: CFX 10-STRUCTURED MESH
The solver? yes.
January 12, 2006, 01:43 |
Hi... I thought CFX Version 5 & above employed unstructured mesh. Only CFX4 used structured mesh for solver.
January 12, 2006, 06:12 |
Yes, I think you're right TB. CFX can handle hex mesh, what doesn't mean it is a structured mesh. CFX-5 and above uses the unstructured mesh aproach, as you can read in the Documentation.
A while ago there was a quite good post, on the Main Forum, about strucured and unstructred meshes and structured and unstructured solvers. Take a look, I think it is quite interesting: http://www.cfd-online.com/Forum/main...cgi?read=39770 [list]Rui |
January 12, 2006, 07:01 |
I missed that post. Thanks for pointing that out,Rui.
So according to Mani's definition, CFX10 used unstructured data on unstructured (either hex or tet type) mesh. It seems like unstructured solver may handle structured mesh in less efficient way, although I'm not sure the reason behind it. |
January 16, 2006, 08:42 |
People often confuse structured and unstructured as being analogous to hexahedral and tetrahedral. This is absolutely not the case. CFX-5 will ONLY deal with unstructured meshes. It can read structured meshes (CFX-4), but they will be dealt with as if they are unstructured.
January 16, 2006, 09:17 |
Yes, I agree with you.
January 16, 2006, 19:18 |
in fact i feel that the handling in unstructured way is much better because for unstructured grid the data structure is pointer based and for structured grid (usually) its index based.
February 1, 2006, 10:52 |
#9 |
CFX is a usstructured solver, u can creat a structured mesh , but its saving format will be unstructured.
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Does a structured hex mesh in CFX have any advantage over unstructured | jbritton | CFX | 3 | March 29, 2012 23:34 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Error Converting ICEM Structured Mesh to CFX | Chebeba | CFX | 11 | October 5, 2006 08:05 |
Structured Mesh in CFX | Ram | CFX | 7 | August 9, 2004 09:54 |
