December 14, 2012, 06:18 |
mesh delete
Rep Power: 15 |
Hi guys.
I need help with deleting meshes in CFX Pre. I have to delete mesh but it is impossible (option is greyed). Can anyone advice me how to delete it? I glued those meshes but I need to delete them right now... Thanks in advance for any advice |
December 14, 2012, 09:09 |
Chris DeGroot
Rep Power: 17 |
I have never encountered a problem deleting a mesh. Please post a screenshot of the problem.
December 17, 2012, 02:34 |
Rep Power: 15 |
Yes I glued both of them and now I have problem as it is on attached file.
December 17, 2012, 06:49 |
hey see on top where you have two meshes.
One with extension .cfx5 and second one with .msh (fluent mesh). Which one you want to delete? right click on that mesh and then select delete !!! |
December 17, 2012, 07:39 |
Rep Power: 15 |
I want to delete these merged meshes, not the ones with extensions.
December 17, 2012, 10:59 |
Bruno
Rep Power: 21 |
This is not the answer you're expecting, but I've seen that too and the easiest way is to just delete both meshed and re-import the one you want. You will not loose the CCL data in the process.
February 5, 2020, 11:51 |
Rep Power: 11 |
If your CFX-Pre setting up is in Workbench and therefore connected with mesh module, it's not available to use Delete Mesh option in CFX-Pre - as far as I know. These option works for meshes imported as a external mesh file e.g. cgns mesh format.
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 10:40 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
