-   CFX (
-   -   volume fraction, Mass fraction and Bulk Mass flow (
Dr.jones January 22, 2006 21:59
Hi! all friend I have a confusing problem when I try to set the value of "volume fraction" in the inlet condition fluid values tab for a gas-liquid two phase problem. If I give the value of volume fraction of different phase, what values should I give to the "Normal speed" of the two flow??are these values also apparent velocity or I should give a same velocity?? this problem confused me and I always give Mass flow rate for every flow.
by the way, when I select "Bulk Mass flow rate" in Boundary Details tab of inlet, I find the volume fraction in the fluid values tab means Mass fraction!(you can find this conclusion from the result file using CFX-POST).Is it true??
Andreas January 25, 2006 05:32
Re: volume fraction, Mass fraction and Bulk Mass f
I also am working on multiphase flows. Since both fluids stream in at the same velocity you must of course set the same velocity as a boundary condition. This is equivalent to setting the specific massflow of each fluid.
