which model in CFX5or10 can handel turb/laminar?
Old   February 24, 2006, 12:28
Default which model in CFX5or10 can handel turb/laminar?
steven
hi,
I heared from a person the other day that a model (I forget the model name) in CFX5or10 can automatically handel the switch between turbulent and laminar model in the same computational domain very well. Say in the same computational doman, some flow region is laminar, some is fully turbulent. So which model is better in CFX to handel such situation? K-omega?
thank you.
Old   February 24, 2006, 13:53
Default Re: which model in CFX5or10 can handel turb/lamina
Robin
Hi Steven,
There is a transition turbulence model extension available with the SST model (which is, incidentally, a k-omega varient). You should review the documentation to ensure you use it correctly and that it does what you need it to do.
Regards, Robin
Old   March 1, 2006, 11:10
airtaohui
The SST(shear stress transport) Model can be applied in this situation. It is a mixer of k-omege model and k-epsilon model.Use k-omege model in the turbulent domain and use k-epsilon model in laminar domain.
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
