February 4, 2006, 11:22 |
How to create biasing in ICEM CFD?
I want to refine my mesh in near wall region to capture boundary layer>But I could not fine any option in icem cfd?can any one tell me that how biasing (fine mesh near wall) can be applied in icem cfd?Thanks in advance.
February 5, 2006, 17:23 |
Re: How to create biasing in ICEM CFD?
You can define local refinement using mesh densities and near wall refinement is usually done with prism layers. You can also define mesh sizes on points, curves and surfaces. Regards, Glenn Horrocks |
February 6, 2006, 00:59 |
HI, If u r using icem-hexa then u can do the baising through edge parameters option. giving spacing 1 n spacing 2 with ratio 1 n ratio2. but if u r doing a tetra mesh then its best to use prism layers. but in prism layers, u can hardly get good quality. regards sridevi
February 6, 2006, 01:56 |
if you are using tetra- mesh, you can also subdivide a prism layer into thinner layers.
Display Modes | |
[ICEM] Problem with volume mesh in ICEM CFD | kolapoasafa | ANSYS Meshing & Geometry | 2 | September 16, 2011 04:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Create STL from ICEM CFD? | Michael B | CFX | 0 | November 2, 2006 09:35 |
ICEM CFD 4.CFX | RK | CFX | 1 | August 12, 2004 18:23 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
