-   -   Extracting Post Data to a Text File (http://www.cfd-online.com/Forums/cfx/22166-extracting-post-data-text-file.html)
Ram February 10, 2006 04:54
Hi
I have a rotating domain model, for which I need to extract data at each radial location. For each Radial location, I need T Total, P total, etc, in a csv format. This data needs to be extracted at a series of radial locations. Can anyone guide me with a simple CCL or Power Syntax code to extract this data.
Thanks
Ram P
TB February 10, 2006 10:00
Re: Extracting Post Data to a Text File
Edit your state file, you may find some function called "Export". Use command export in command window to automate the process. Refer to user manual about command "export".
Ram February 13, 2006 07:25
TB
Thanks for your idea. I searched the archives and found the required code to automate the process
Ram P
Bile March 3, 2006 07:20
Hi, Ram, I have the same question. Can you show me the locaiton of the code you have found? Thank you.
