February 11, 2006, 09:17 |
Error detected by routine PEEKR
Dear All,
When i start simulation including radiattion model, simulation is stopping with following error. Details of error:- ---------------- Error detected by routine PEEKR CDANAM = /FLOW/CONTROL/CPU_TIME/TOTAL CRESLT = NONE And my simulation is running well, if i exclude radiation model. Can any body comment or suggest on this error: 1.what is the reason for this error. 2.How to over come this error. Thanks Crash |
February 12, 2006, 22:32 |
Re: Error detected by routine PEEKR
Dear Crash,
That error happens after another fatal error has ocurred. The question is what caused the original fatal error.. Are you running Monte Carlo/Discrete Transfer, or P1? If you are running MC/DT, what is the coarsening rate you are trying to achieve? Try reducing the coarsening rate to value smaller than 64 (default). For example, 16, and see if the error continues.. By any chance, are you combining multiple CAD faces (which happens to be disconnected in space) into a single boundary condition patch? The coarsening algorithm may be failing.. Opaque.. |
February 13, 2006, 00:27 |
Dear Opaque,
Thanks for ur suggestion.Now it is working with lower coarsening rate.I am using DT model. Regards Crash |
Error detected by routine PEEKR | dada1204 | CFX | 3 | October 25, 2010 20:09 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
Error message subroutine PEEKR | Vanessa | CFX | 0 | August 31, 2006 13:17 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
Error detected by routine PEEKR | zhxc | CFX | 0 | June 6, 2005 00:28 |
