Force on body by velocity compared to force_y@... |
February 14, 2006, 12:57 |
Dear posters, it would really help me if anyone could give me a hint with this:
in order to calculate the Force on a bluff body normaly one uses force_y@bluffBodyName. This shuould calculate the y component of Integral(sigma dot normal)*dS this integral is equal to areaInt((-p+2*Dynamic Viscosity*(Velocity u.Gradient X))*Normal X)@bluffBodyName + areaInt(Dynamic Viscosity*(Velocity u.Gradient Y+Velocity v.Gradient X)*-Normal Y)@bluffBodyName + areaInt(Dynamic Viscosity*(Velocity u.Gradient Z+Velocity w.Gradient X)*-Normal Z)@bluffBodyName But they are not equal! Question: Why? (I need to calculate the Integral this way, because in my application I need to direcly acsess the memory of the solver with Fortran routines and map forces from a deformed to a reference configuration) |
February 14, 2006, 13:08 |
Re: Force on body by velocity compared to force_y@
Dear Stefan,
I assume you are using a laminar model because otherwise you cannot assume that the shear force is visc*(grad vel + gradT vel).. Recall that the turbulence models use wall functions, and the expression for wall shear is C * (Vel Node - Vel Wall) or something in that direction.. Good luck, Opaque.. |
February 15, 2006, 10:27 |
Thank's a lot for your answer.
Yes I am using a laminar model the reynolds number is only 20. no wall function or anything like that is used. using f_x@cylinder I get 5.56847e-005 [N] and using visc*(grad vel + gradT vel) leads to 5.48238e-005 [N] which is not the same and I need it to be exact. Really looks like I foregot something. Can you think of anything else that went wrong? greetings Stefan |
February 15, 2006, 10:29 |
Foregot to say that the fluid is visous and incompressible
Body force in CFX | enghamed | CFX | 3 | November 27, 2010 05:28 |
Body force at the cell face | Souviktor | Fluent UDF and Scheme Programming | 0 | March 31, 2009 09:54 |
Body Force & User Subroutines In Fidap | Mohammad Aghakhani | FLUENT | 0 | May 21, 2007 18:01 |
DPM body force Doubt | Sandilya | FLUENT | 0 | May 21, 2007 14:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
