Monitoring non-boundary faces
Old   February 22, 2006, 13:33
Default Monitoring non-boundary faces
Andrew
Hi,CFX Guys
For a transient run, is it possible to monitor the average value on a plane which is not a boundary face?
Regards!
Andrew
Old   February 24, 2006, 18:27
Default Re: Monitoring non-boundary faces
Andrew
Can someone answer this?
Best regards!
Old   February 26, 2006, 03:50
TB
In Solver Manager? The answer is no. You can only monitor a point value when the solver is runing.
In Post? The answer is yes as long as you have defined your transient files that you wishes to save in Pre.
Old   February 26, 2006, 04:03
Andrew
Thanks a lot, TB.
Could you please explain in details how to do this in Post? I am trying to use this function to get tracer curve at an internal location of a reactor.
Best regards!
Andrew
Old   February 26, 2006, 04:31
TB
there're some examples in user manual. Search for command 'load','timestep','massflowAve','export' etc in user manual.... You can automate the process using command window (look for icon on top of Post GUI)....
Post used PERL language.... It should be pretty easy to learn....
Old   February 26, 2006, 04:44
TB
or you can use the x-y graph supplied by POST. I normally exported everything out from POST and plotted my graph in Matlab/Excel anyway. It's up to you to decide which way suit you the best.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Internal Faces to boundary patch conversion robingilbert OpenFOAM 4 March 24, 2010 10:40
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
extending boundary layer to mesh faces kb FLUENT 0 September 28, 2007 03:26
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
