Solver error in Parallel run 255
Old   February 28, 2006, 03:38
Default Solver error in Parallel run 255
M
I am trying to run a combustion case in CFX 5 using a flamelet library created un CFX RIF. When i run the case it returns with the following error message:
Details of error:- ---------------- Error detected by routine INIMEM Fatal error initialising the stacks. ICOM,IRET,IERR 100 0 -1 CRESLT = ERR and then it returns with error code 255.
The mesh is one i built using cfx mesh, i then imported the mesh into ICEM and to smooth and coparsen it. when i did import the mesh into ICEM i chose the option to create a part form the surfaces. could this be the reason my solver is failing as it now has many many parts?
Thank you in advance,
M
Call for help! Cfx error in Parallel run. yq11ys CFX 5 November 28, 2022 22:25
multiphase solver - parallel processing - GAMG thibault_pringuey OpenFOAM Programming & Development 2 August 27, 2013 22:03
new Solver won't run parallel Chris Lucas OpenFOAM 4 January 10, 2012 10:30
parallel run for fsi simulation??? smn CFX 2 July 19, 2009 04:04
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
