March 6, 2006, 07:30 |
Insufficient memory allocation
hi, I am using cfx-5.7.getting insufficient memory allocation error in solver.if anybody has solution about this plz ans my query.
regards kiran |
March 6, 2006, 07:42 |
Re: Insufficient memory allocation
hello kiran, Increse memory factor for your problem. If you run from command prompt: e.g.:
cfx5solve -size 1.5 -def ..... GUI: In Solver manager under Solver tab you can find the memory options. If you dont see Solver tab click Advanced controls check box. For more details have a look in CFX solver manager documenatation: *Starting the CFX-Solver from the Command Line* Regards, Siv |
March 6, 2006, 08:02 |
hi siv, thanks a lot.I tried it and found it.now another querry i wanted to ask you,how to use turbo mode in cfx post to rotate a domain.or tell me about rotating domain and fluid fluid interface btn stationary and rotating domains
regards kiran |
March 6, 2006, 08:12 |
i dont have any experience with Turbo mode.sorry Once i read in CFX post documentation. Its not so difficult i guess.
about numeca harmonic method Memory allocation failed | uqzcpo | Fidelity CFD | 2 | October 7, 2011 22:10 |
Insufficient virtual memory | sammi | Phoenics | 4 | April 8, 2009 13:32 |
Memory allocation problem | Ammar Abdilghanie | FLUENT | 5 | February 19, 2007 18:15 |
Memory allocation problem | shhe | CFX | 4 | January 6, 2004 23:00 |
memory allocation | strudl | CFX | 1 | October 5, 2003 10:26 |
