Mointor points
Hi, after a run i want to view monitor point data, i've extracted the .mon file from the .res, but cant make sense of the text file that comes out, how do i know which numbers relate to which points? Thanks
Tim |
Re: Mointor points
Normally you would just use "Monitor Finished Run" in the Solver Manager to review the convergence history and it would include the monitor point history too. M
Re: Mointor points
The order of the data is listed in the header of the mon file. If you need to extract you monitor data, do as Mike has suggested and plot them with the Solver Manager. If you right click in this plot you can then export the plot data to a .csv file.
Regards, Robin |
