Icem CFD 10: Align vertices of splitted edges
Hello to everybody,
I'm meshing a simple pipe, using Hexa grid and splitting the domain with an O-grid for the boundary layer resolution. To improve the quality of the mesh, I've splitted the edges of the O grid parallel, using the command "Edit Edge". My question is: is it possible to align these vertices used to split the edges,with other vertices? Thank in advance for the attention, Michele |
Re: Icem CFD 10: Align vertices of splitted edges
Why don't you just use the edge parameters to set higher desities, instead of splitting the edges? Splitting edges will make your blocking more (unnecessarily) complex. /C
Probably I don't explain very well my question!
I don't split the edges, but I add a control point inside the edge to force the edge shape, using some additional points to obtain a spline curve. So my question is: can I align the spline control points in some way? Thanks again for your attention!! Michele PS I've used the command: BLOCKING - Edit Edge - Split edge - Method spline |
