March 10, 2006, 00:36 |
about CFX-mesh, help me please.
Dear friends,
I made my model with Workbench and use CFX-mesh to generate mesn. My model is a cylinder with two open-ends as Outlets and a hole in the middle as Inlet. The length of cylinder is 14.7 mm, diameter 2.8 mm, diameter of the hole is 1.4 mm. The fluid is compressed air. Which settings in CFX-mesh are important to my mesh? Thank you in advance. Erick. |
March 13, 2006, 12:53 |
Re: about CFX-mesh, help me please.
haven't used CFX-mesh for a while, since now using ICEM, but I think to remember u need a global maximum mesh size and perhaps some inflation at the surfaces. The size will depend on the characteristic of the flow. If you expect high gradients, you need mesh refinement - especially at the inlet. Hope this helps a bit further.
TobiasZ |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
CFX Mesh Deformation problem | Silmaril | CFX | 7 | October 19, 2010 10:00 |
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! | Vu Trinh Tuan | CFX | 11 | March 28, 2005 19:04 |
importing mesh from ICEM CFD into CFX 5 | Jay | CFX | 2 | November 12, 2002 13:46 |
