how to check qlty of mesh?????
Hello friends my question is how to check quality of mesh generated using CFX? PLZ reply.
Re: how to check qlty of mesh?????
Make your mesh finer. If you get the same results it was good to start with. If you get different results, it's not good.
Also check your Wall Scale. Do the "Flow Around a Blunt Body" tutorial, it will give you an idea! /C |
Use CFX-post to verify the mesh quality.Plot y+ and have a look. make sure your meash is even. Goodluck, Rajit
thank you, i will try.
