how to check qlty of mesh?????
Old   March 15, 2006, 07:36
Default how to check qlty of mesh?????
vijesh joshi
Hello friends my question is how to check quality of mesh generated using CFX? PLZ reply.
Old   March 15, 2006, 12:17
Default Re: how to check qlty of mesh?????
Chebeba
Make your mesh finer. If you get the same results it was good to start with. If you get different results, it's not good.
Also check your Wall Scale. Do the "Flow Around a Blunt Body" tutorial, it will give you an idea!
/C
Old   March 15, 2006, 19:40
Rajit
Use CFX-post to verify the mesh quality.Plot y+ and have a look. make sure your meash is even. Goodluck, Rajit
Old   March 15, 2006, 23:33
vijesh joshi
thank you, i will try.
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
