-   -   remesh in cfx (http://www.cfd-online.com/Forums/cfx/22307-remesh-cfx.html)
Nan March 16, 2006 17:23
remesh in cfx
Hi, there,
Is any way to set "remesh" for each time step in cfx-pre or anywhere else?
Thanks.
TobiasZ March 20, 2006 10:46
Re: remesh in cfx
Hi, I think there might be a possibility. I found an example in the CFX5-manual a long time ago about a ball deforming while it hits the ground. In this example the mesh had to be reread for each time step I believe to remember. Can't tell you more about it, but hope this helps a bit further.
TobiasZ
Nan March 20, 2006 12:49
Thanks Re: remesh in cfx *NM*
Glenn Horrocks March 20, 2006 16:55
Re: remesh in cfx
What are you trying to do? Deforming grids (but the same mesh topology), or do you want to do a complete remesh of the internal mesh from the outer boundary?
Nan April 5, 2006 10:37
Re: remesh in cfx
Hi, Glenn,
I just saw your response.
I am working on a problem similar to moving piston. When the mesh moves, it creates negative elements.
Thanks.
