-   -   BC setting (http://www.cfd-online.com/Forums/cfx/22319-bc-setting.html)
Richard March 18, 2006 10:13
BC setting
Hi, what the different of setting average pressure for inlet and mass flow rate for outlet,with mass flow inlet & pressure outlet
steve March 20, 2006 11:49
Re: BC setting
Hi richard!! If u use a mass flow rate at the outlet, you enforce the fluid to go out of your domain with a normal direction. If you use a pressure at the outlet, then your fluid are not going to be enforced to go out normally to the boundary limit. The BC could modify the velocity upstream the outlet.
steve
