-   -   Importable grid file format for cfx 5.71 (http://www.cfd-online.com/Forums/cfx/22357-importable-grid-file-format-cfx-5-71-a.html)
Oliver March 27, 2006 10:20
does anyone has the description (or the link to) of an unstructured grid file format, which can be imported by cfx 5.7.1 or greater? E.G. Patran (where I don't understand the boundary definition within the named components). Favoured is ascii, but binary is also welcome (in particular it is sufficient documented). If possible, I don't want to use it via a library (e.g. as cgns).
In my opinion, the file only has to have the following sections
Thanks in advance!
Oliver
nodes 1 x1 y1 z1 2 x2 y2 z2 ... elements/cells (here hexaedrons) 1 1 2 3 4 17 16 15 14 1 21 22 23 24 99 100 101 102 ...
boundary1 (here quads) 1 1 2 3 4 2 5 6 7 8
boundary2 ...
Chebeba March 27, 2006 15:37
Re: Importable grid file format for cfx 5.71
How about NASTRAN? Looks a lot like what you described. Here's a small example with 7 hexa's.
/C
$ Nastran input deck
SOL 103
CEND
BEGIN BULK
GRID 1 059.00000-8.0000015.00000 0 0
GRID 2 0-6.00000-8.0000015.00000 0 0
GRID 3 059.000004.00000015.00000 0 0
...and so on down to:
GRID 16 055.40000.4000001-11.4000 0 0
$ Volume element data for family SOLID
PSOLID 1 0 0 0
CHEXA 1 1 1 2 4 3 5 6 8 7
CHEXA 2 1 9 10 12 11 13 14 16 15
CHEXA 3 1 11 12 3 4 15 16 7 8
CHEXA 4 1 10 9 2 1 14 13 6 5
CHEXA 5 1 12 10 1 3 16 14 5 7
CHEXA 6 1 9 11 4 2 13 15 8 6
CHEXA 7 1 13 14 16 15 6 5 7 8
ENDDATA
Oliver March 28, 2006 04:51
Hi Chebeba,
thanks for your answer! Yes, this works (after I reformatted your example). But how can I define several boundary faces? Or several cell zones? I changed some parameters from 0 to 1 or to 2, but nothing happens within CFX.
Do you have a documentation about the different parameters?
Regards
Oliver
Chebeba March 28, 2006 09:13
As usual, Google is your friend:
http://www.mscsoftware.com/support/p...elease2001.pdf
(Lots of stuff about the solver, I didn't read it all but looks like you should find what you want somewhere in there... /C
Oliver March 30, 2006 11:40
Hi Chebeba,
thanks again. For Nastran, it seems that cfx ignore the boundaries. But I've got now the necessary information on the patran neutral file format.
Regards
Oliver
