Edge of mesh
Old   April 4, 2006, 19:51
Default Edge of mesh
Nan
I am using icemcfd create tet mesh. I found that the nodes near the surface edge sometime create another edge. In another words, the nodes are not on the real suface edges. There is another line very close to the edge.
How can I solve this problem?
Thanks in advance.
Old   April 4, 2006, 21:06
Default Re: Edge of mesh
Nan
Also sometimes the mesh at the edge is normal to the surface.
Old   April 5, 2006, 02:48
Chebeba
Scroll down a bit on the page, there is an old discussion on this topic.
Old   April 5, 2006, 12:07
myron
Generally the answer would be to make sure you have geometry curves at all sharp edges you wish to capture with mesh, and points at all corners you with to capture with mesh. Geometry > Repair > Build Diagnostic Topology with the filters for points and curves turned on does a pretty good job of this.
If you still have problems after getting the correct set of curves and points capturing only 'hard' features - you probably have geometry problems where the surfaces don't match nicely.
Old   April 5, 2006, 12:34
Nan
Thanks.
Yes. You are right. I have problems on geometry.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
[ICEM] mesh trailing edge wedge josip76 ANSYS Meshing & Geometry 6 September 1, 2013 12:31
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
