CFX and Fluent
Old   March 30, 2006, 04:50
Default CFX and Fluent
Q
Can I import Mesh generated by Gambit into CFX or not.
Also Can I export data computed using CFX solve into other software like Fluent or atleast tecplot.
Q
Old   March 30, 2006, 05:57
Default Re: CFX and Fluent
ms
yes, if you choose your solver as ansys in gambit and then export mesh as normal you get a .cdb file while can be read in cfx. In cfx when you inport your mesh you obviously also need to match the import type as ansys.
I believe for the 2nd part you can use the export command in the solver manager but I have never used it. It is in the help guide though.
Old   March 30, 2006, 12:00
Q
The problem is that My mesh in fluent is 2d and when I export this in Ansys or any other format and try to imprt this file in cfx I get the problem saying missing 3d elements.
Is there work around for this
Old   March 30, 2006, 15:34
Robin
Create 3D elements.
Old   March 30, 2006, 18:14
TG
You could wait until after the 2 companies merge. Then by definition fluent data will also be ansys data.
Old   March 31, 2006, 02:53
Q
Comon you guys give me some worthwhile advice not like this
How to create 3D elemnts
Old   March 31, 2006, 04:46
ms
you have to extrude it 1 cell into the 3rd dimension. You can then use symmetry planes as your wall boundary conditions. You have to make it 3d otherwise it will not work. Best of luck.
Old   April 1, 2006, 06:19
Mikhail
What about tecplot or ICEM with POST VIEW module?
Comparison of fluent and CFX for turbomachinery Far CFX 52 December 26, 2014 18:11
CFX or Fluent for Turbo machinery ? Far FLUENT 3 May 27, 2011 03:02
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 02:43
Fluent and CFX Ale CFX 1 July 2, 2008 18:19
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 04:13
