Menter one-equation k-epsilon model
Hello, all,
Can anybody let me know how one can use Menter's one-equation k-epsilon model as the turbulence model? It's discussed in the CFX manual, which seems to say that it is available as an export control parameter in CFX-Pre, but it's not in the expert control parameters panel (or if it is, it's well-hidden). I'm using CFX-10.0. Best regards, MTogneri. |
Re: Menter one-equation k-epsilon model
Dear MTogneri,
An equation for k-epsilon has two equations.. You may be referring to the one-equation Menter model for turbulent eddy viscosity.. In CFX-Pre physics tree, use right click on TURBULENCE MODEL and select Edit in Command Editor.. Replace k epsilon (or whatever you already have) by Eddy Viscosity Transport Equation You must setup the k-epsilon (or other) first, so you will the boundary conditions right, then you can ignore the warnings that come from using the expert/hidden model. Good luck, Opaque |
