ICEMCFD creates irregular surface layers ?
Old   April 10, 2006, 13:08
Default ICEMCFD creates irregular surface layers ?
ingear
Hi, in ICEM 5.1, I imported the IGES geometry, then repaired the geometry, created the curves and points. The tetra mesh was good. But when I finished generating prism layers, the mesh did not conform to the geometry. Instead, the surface was rough, very irregular. Does someone know how to fix the prism layers? Thank You very much.
-MG
Old   April 10, 2006, 14:37
Default Re: ICEMCFD creates irregular surface layers ?
James Date
Try reducing the triangle tolerance in the global mesh settings menu. This might force the surface mesh to conform more closely to the CAD geometry.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 09:29
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
refine surface layers with icem Andreas CFX 0 October 24, 2005 04:02
