.F on WINNT works and compiled for AIX does not
Old   April 10, 2006, 09:17
Default .F on WINNT works and compiled for AIX does not
Daiga
Hello, does anybody knows where should I look for the problem...
I had a standart script - which calculates x and y components of gradient of additional variable.
This script compiled on WINNT worked correctly. Now I am able only to use cfx account on AIX platform, (which is not on my computer but I reach it by net) and here the script (it is compiled succesfully by fortran for aix and path to aix/lib*.so is correct) anyway causes error of the solver.
The beginning of .F file is like that
#include "cfx5ext.h"
dllexport(gradWx)
SUBROUTINE GRADWX(NLOC,NRET,NARG,RET,ARGS,CRESLT,CZ,DZ,IZ,LZ, RZ )
#include "MMS.h" #include "cfd_constants.h" #include "stack_point.h" C ------------------------------
INTEGER NLOC, NRET, NARG
CHARACTER CRESLT*(*)
REAL RET( 1:NLOC,1:NRET ), ARGS( 1:NLOC,1:NARG )
INTEGER IZ(*)
CHARACTER CZ(*)*(1)
DOUBLE PRECISION DZ(*)
LOGICAL LZ(*)
REAL RZ(*) ............ ________________________________________
I have faced with error like that '' Unable to load symbol gradWx from /fastfs/work/niiumbra/cfx/aix/l- | | ibgrady.so: Function not implemented (gradWx)''
Message: | Stopped in routine UR_REGISTER
or (when using gradwx instead of gradWx)
Error detected by routine PEEKCS CDANAM = /FLOW/PHYSICS/LATEST/ZN1 /SL1 /AV1 /CELAVMAP CRESLT = NONE
or Error detected by routine DELDIR CDRNAM = ÿÿÿÿþ±H ÿÿÿÿþ±D ÿÿÿÿþ±@ ÿÿÿÿþ±h ÿÿÿÿþ±` ÿÿÿÿþ±< ÿÿÿÿþ¹Ã °ÿÿÿÿ ÿÿÿ CRESLT = ILEG °°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° °°°
Could anybody explain me does the name of dllexport should be the same I use in name of subroutine or there should be difference? Are there some important things in .F syntax I should use when compiling in Fortran for AIX?
Where should I look for the solution of the problem?
with best regards,
Daiga
Old   April 10, 2006, 10:10
Default Re: .F on WINNT works and compiled for AIX does no
opaque
Dear Daiga,
Would you mind posting the section of CCL where the User routine is defined, or referenced, i.e. USER ROUTINE DEFINITIONS..
Good luck, Opaque..
UDF - Interpreted works and compiled doesn't AlwaysLearning FLUENT 9 October 30, 2018 00:52
Difference between interpreted and compiled for DEFINE_ADJUST? KatyaM Fluent UDF and Scheme Programming 1 November 3, 2009 09:30
interpret works fine but compile doesn't Jan Balemans FLUENT 0 March 14, 2008 09:41
.F compiled on Winnt works, but on AIX doesn't Daiga CFX 11 May 9, 2006 07:44
