April 26, 2006, 11:08 |
USING 'TORQUE FUNCTION'
Hope anyone can help me:
I am trying to get the torque from a rotating channeled disc by using the function TORQUE, but with no success. I am using the following format: torque(Axial Direction Z )@Plane 1 The disc rotates about global Z (that's why I chose Axial Dir Z) and it does not matter if I select any surface of the disc (either perpendicular or parallel to rotation direction...), it gives an error. Any help is welcomed (I am using CFX10) carlos. |
April 26, 2006, 11:14 |
Re: USING 'TORQUE FUNCTION'
Dear Carlos,
I am not sure why you are using the syntax torque(Axial Direction Z )@Plane 1 since the documentation implies that torque()@location, and force()@location do not take an argument list.. If you want the coordinate axis component, you must use torque_?()@location where ? can be x, y or z on the global coordinate frame.. If you create a local coordinate frame named Joe Frame, you can also use torque_?_Joe Frame()@location Good luck, Opaque |
April 26, 2006, 12:15 |
Hi Opaque, thanks for answering. Obviously I have not understood clearly the instruction in the documentation. The example:
torque(Axial Direction Z )@VANES throws and error: ERROR Error in setting: "TORQUE" via the expression: torque(Axial Direction Z )@VANES torque(Axial Direction Z )@: read successfully, and then error found at item: VANES Call to torque: number of arguments (1) does not match expected value (0) which agrees with your former message. But if I just use: torque( )@VANES it gives the following error: ERROR Function 'torque' must have an axis. i.e. it asks for an axis... so I just changed VANES for 'Z' or 'AXIAL DIRECTION Z' and it succeeds reading up to @... then it breaks. Does 'global Z' must be 'declared' in a way in order to be understood by the function? PS. Unfortunately I am using 'trial and error' method to use this function... I am left with nothing but that. Carlos. |
April 26, 2006, 13:44 |
Dear Carlos,
Again, the documentation section ANSYS CFX-Post, Release 10.0 | CCL and CEL in ANSYS CFX-Post | CFX Expression Language (CEL) in ANSYS CFX-Post | says torque_Axis[_Coord Frame]@Location Notice that in ANSYS CFX documentation less/greater brackets (which I could make it work in html) imply required, and square brackets means optional Therefore, for your case should be torque_z()@VANES Good luck, Opaque |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
