Bug for cylindrical components of flow direction ?
Old   May 2, 2006, 03:51
Default Bug for cylindrical components of flow direction ?
pierre victor cueille
I am currently trying to run a case with a mass flow rate for the Inlet boundary condition.
Considering the flow is not normal to the inlet, I have been trying to impose direction to this inflow. The problem has come when imposing these components. Since they have no dimensions, I expect these are some trigo' functiuns of the flow's inclination, but input value > 1 is considered valid. Moreover, changing the value order of these components ( from 1 to 10000 in axial ) does not change the flow solution.
has anyone encountered such problem ?
Thanks
Pierre
Old   May 2, 2006, 09:37
Default Re: Bug for cylindrical components of flow directi
opaque
Dear Pierre,
- The ANSYS CFX solver will normalize the flow direction vector.. It allows user to specify direction vector using "common numbers" such as (1,1,0) for 45 degrees inclination on the xy plane..
- For a plane boundary, changing the normal component should not change your results (not sure about not planar boundaries) since mdot = density * area ( v dot n).. Therefore, the axial component, i.e. v dot n, is already specified as v dot n = mdot / (density * area)..
You should contact CFX help desk for additional information, Good luck,
Opaque
specifying the flow direction in periodic boundary joanna FLUENT 2 February 27, 2006 21:09
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Flow directin components. Nahari Ziv FLUENT 1 March 28, 2005 20:12
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
