Multi-domain
Old   May 10, 2006, 18:53
Default Multi-domain
Camilo Costa
In my simulation i have only one domain, if i divide this domais into tow, my simulation will go faster?
THX FOR HELP?
Old   May 11, 2006, 00:33
Default Re: Multi-domain
jemteo
HI,
i think it will be slower cos there is a need for interfacing. i had a problem where i have almost 100 sub-domains and each subdomains have element scatteredd (i.e. disjointed) it cannot even be imported into CFX from ICEM.
Old   May 11, 2006, 06:00
Forrest
I assume you meant running your case in parallel. If you run a calculation using more than one processor, first thing you need to check is what would be your mesh size. If your mesh size is large, it would be faster using more machine working together. It depends on percentage of mesh 'overlap' between each partition. If computing overhead is not due to large mesh size (for example, due to radiation calculation), running in parallel is not going to be helpful, may slow down, as jemteo pointed.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
Error Message after switching to multi domain physics chili023 CFX 3 June 5, 2010 05:28
Multi flow in two different domain arunss CFX 3 May 11, 2010 16:06
multi domain heat transfer prob mohammed zubair CFX 1 June 27, 2006 09:30
