Question about CFX-Pre Variables
Old   July 28, 2009, 08:04
Default Question about CFX-Pre Variables
seaharrier is on a distinguished road
Hi,EVERYONE,
I am simulating Droplet-Gas two-phase flow, and I want to use the impact angle of droplets on the wall to compute other variable,
But I can not find this variable in CFX-Pre ,
COULD someone give me a help?
Thanks!
seaharrier is offline   Reply With Quote
Old   July 29, 2009, 07:13
stumpy is on a distinguished road
I assume this is Eulerian 2 phase flow. Perhaps you could create a boundary-only Additional Variable, setting it to a function of the phase Velocity vector and the surface normal vector ( i think that variable is called "Normal Direction X | Y | Z"). I think boundary-only AV's are a CCL-only feature (I could be wrong here) - if so, just create a normal algebraic AV, then add the Boundary Only parameter to the CCL. You'll need to check the RULES files in the <install root>/<version>/CFX/etc directory to see exactly the correct syntax.
stumpy is offline   Reply With Quote
How to set up a CFX Pre? winglet CFX 4 July 2, 2009 12:46
CFX Pre Error - has anyone seen this? Jenny CFX 1 January 29, 2009 02:38
CFX 10 question DAK565656 CFX 0 August 6, 2007 00:06
simple question about ICEM CFX sleepinglily CFX 0 October 27, 2004 13:15
Question about meshing / solution scheme of CFX Coriolius CFX 8 August 1, 2004 18:39
