how to set if the domain in vacuum condition
Old   May 22, 2006, 22:33
Default how to set if the domain in vacuum condition
jasonchang
Hi,all
I am simulate at such condition,there is only the inlet and wall boundary condition,without outlet. It is in vacuum in the domain,with the pressure 0 Pa.How should I set in cfx .Any suggestion will be appreciated.
If the pressure is 1000Pa, with water to fill the domain, is it a single phase ?
Thanks a lot.
with regards,
Old   May 23, 2006, 14:06
Default Re: how to set if the domain in vacuum condition
Robin
Hi Jason,
There will always be some pressure, even in a vacuum. You could use Air Ideal Gas as the gas phase in the vacuum and set the pressure to be very low, but not zero.
If you are interested in how the water fills the domain you will need to solve this as a 2 phase problem. Homogeneous multiphase with free surface would do. Some of the water would evaporate, since liquid water will not remain liquid in a vacuum, but assuming your water fills the vessel quickly this may not be an issue. Otherwise, you will also need to account for the phase change.
Regards, Robin
Old   May 23, 2006, 20:40
jasonchang
Dear Robin,
Thanks for your advice. It's very useful to me.
By the way, This vessel has no outlet,only with all and inlet at the bottom.The wall is made of sand ,only allow the air flowing out.Indeed it is use for foundry.
How should I setting the boundry condition? Best wishes.
Jason
Old   May 25, 2006, 13:16
Robin
Hi Jason,
Investment cast moulding is a challenging thing to simulate. Two approaches may be possible:
1. Add a mass sink at the wall to draw air out.
2. Add a porous domain around your part to simulate the sand. You can add appropriate resistances to the movement of air and a higher resistance for the liquid.
Regards, Robin
Old   May 26, 2006, 01:34
jasonchang
Dear Robin,
Thank you.I will try it as what you suggest.
Another problem confuses me: How to set the inlet boundary condition in transient flow ,for example,the inlet pressure.
I try to set it use static pressure and total pressure,but it didn't success,because the fluid I used was multiphase,which is compressive.But just as showed in the CFX_POST ,the Pressure only can be used for incompressive fluid. Regards,Jason
Old   May 26, 2006, 03:43
jasonchang
Hi,Robin,
Can you tell me how to set the mass sink or porosity mdomain in detail? I have never use it before.
Regards,
Jason
Old   May 26, 2006, 08:31
jasonchang
Hi, I browsed the "HELP" of CFX10.0,and found that mass sink can only be used in multicomponent flow. My simulation use water,or alminium at last,for the fluid, so perhaps mass sink doesn't fit my simulation.Maybe I should consider porous model just as what you suggest.But haven't use it before.I'm not sure if I can do it successfully.
Old   May 26, 2006, 15:45
Robin
Sorry, too much detail for me to get into here. I suggest contacting support or reviewing the user documentation.
-Robin
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
How to set domain translation and rotation in CFX ricardo.halfeld CFX 7 September 8, 2009 18:22
Set the boundary condition chris FLUENT 0 July 24, 2006 21:05
how to set boundary condition Huairong Huang Phoenics 4 April 30, 2006 12:31
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
