Home > Forums > CFX
IGES on turbogrid
Old   May 22, 2006, 03:37
Default IGES on turbogrid
clo
Hi everybody I'm trying to learn how to use turbogrid, and I wanted to import an IGES turbine geometry on it. Is it possible to do it? Have I to import it in BladeModeler and than export my geometry as turbogrid geometry? Thank you
Old   May 22, 2006, 12:29
Default Re: IGES on turbogrid
deLuther
I suppose that with BladeModeler (I don`t used it) comes some kind of utility to transfer CAD models to its own geometry. BladeGen (predecessor of BladeModeler) had such utility. This utility located in File->New->Data Import Wizard... Because interface of BladeModeler almost same I suppose that you can find it on the same place...
Old   May 22, 2006, 12:36
clo
Thanx, I also supposed BladeModeler can help to solve the problem...Do you know if it is possible to save mesh for other solvers other than CFX (for example comet)?
Old   May 23, 2006, 04:35
deLuther
There is a problem with export to Comet, ICEM CFD not supporting this format. But if ICEM not support it, then Turbogrid especially can`t. Maybe such export will be possible through CGNS format. I don`t now of Comet mesh format support. And related to previous post... I did not say that BladeModeler necessarily has such tool, maybe ANSYS removed it... But I hope not.
Thread Tools
Trackbacks are On
Importing ICEM mesh in TurboGrid ayothicfd Main CFD Forum 0 October 8, 2011 10:23
Problem importing iges file to Gambit Tassos FLUENT 0 May 7, 2008 04:28
IGES Import/Export problems with Gambit 2.2.30 Nick Lavery FLUENT 4 July 22, 2005 01:32
IGES surface doesn't work pete CFX 5 July 15, 2003 23:30
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 13:22
