May 22, 2006, 03:37 |
IGES on turbogrid
Hi everybody I'm trying to learn how to use turbogrid, and I wanted to import an IGES turbine geometry on it. Is it possible to do it? Have I to import it in BladeModeler and than export my geometry as turbogrid geometry? Thank you
May 22, 2006, 12:29 |
Re: IGES on turbogrid
I suppose that with BladeModeler (I don`t used it) comes some kind of utility to transfer CAD models to its own geometry. BladeGen (predecessor of BladeModeler) had such utility. This utility located in File->New->Data Import Wizard... Because interface of BladeModeler almost same I suppose that you can find it on the same place...
May 22, 2006, 12:36 |
Thanx, I also supposed BladeModeler can help to solve the problem...Do you know if it is possible to save mesh for other solvers other than CFX (for example comet)?
May 23, 2006, 04:35 |
There is a problem with export to Comet, ICEM CFD not supporting this format. But if ICEM not support it, then Turbogrid especially can`t. Maybe such export will be possible through CGNS format. I don`t now of Comet mesh format support. And related to previous post... I did not say that BladeModeler necessarily has such tool, maybe ANSYS removed it... But I hope not.
Importing ICEM mesh in TurboGrid | ayothicfd | Main CFD Forum | 0 | October 8, 2011 10:23 |
Problem importing iges file to Gambit | Tassos | FLUENT | 0 | May 7, 2008 04:28 |
IGES Import/Export problems with Gambit 2.2.30 | Nick Lavery | FLUENT | 4 | July 22, 2005 01:32 |
IGES surface doesn't work | pete | CFX | 5 | July 15, 2003 23:30 |
Importing I-DEAS unv file | hbetb | FLUENT | 1 | August 10, 2001 13:22 |
