subroutine FORTRAN // CFX in Spain
Hi! I've modified the subroutine used in the tutorial 17 (air conditioning) for my own sensor. If there is: H2 Ideal Gas.Mass Fraction > CLIM1 = 0.003 then I want my input of H2 to be closed.
The velocity Y of the input will be: H2_ON*10 [m s^-1] CSENSOR = probe(Mixture.H2 Ideal Gas.Mass Fraction)@Detector, where Detector is a Monitor Point. Could somebody check if my routine is right? #include "cfx5ext.h" dllexport(h2_on) SUBROUTINE H2_ON ( & NLOC, NRET, NARG, RET, ARGS, CRESLT, CZ,DZ,IZ,LZ,RZ ) CD Control an input H2 by a sensor #include "parallel_partitioning.h" INTEGER NLOC,NARG,NRET CHARACTER CRESLT*(*) REAL ARGS(NLOC,NARG), RET(NLOC,NRET) INTEGER IZ(*) CHARACTER CZ(*)*(1) DOUBLE PRECISION DZ(*) LOGICAL LZ(*) REAL RZ(*) CHARACTER*20 ROUTIN PARAMETER(ROUTIN='HEAT_SOURCE') INTEGER ILOC, NCLOOP REAL CSENSOR, CLIM1, VALUE C initialize H2 input to be on DATA VALUE/1.0/ C initialize the variable that keeps track of the last time step DATA NCLOOPLAST/-1/ SAVE VALUE C Initialise RET() to zero. CALL SET_A_0( RET, NLOC*NRET ) CSENSOR = ARGS(1,1) CLIM1 = ARGS(1,2) NCLOOP = INT(ARGS(1,3)+0.1) IF (NCLOOP .EQ. 1) THEN C At the start of a new timestep. It is time to re-assess whether to turn on or off the H2 input. IF (CSENSOR .GT. CLIM1) THEN C Turn off H2 input VALUE = 0.0 ELSE VALUE = 1.0 ENDIF ENDIF DO ILOC = 1, NLOC RET(ILOC,1) = VALUE ENDDO C Set success flag. CRESLT = 'GOOD' END Does anybody know where I can find someone who knows how to use Ansys-CFX in Spain?? Thank you very much!!! |
