-   -   how to export x- and y-axis of isosurface ? (http://www.cfd-online.com/Forums/cfx/22611-how-export-x-y-axis-isosurface.html)
Tom May 28, 2006 21:23
i did the wave propagation simulation, and plot the isosurface of the elevation, but i do not know how to export the the x- & y- axis values of the isosurface. i need plot X .vs. elevation, another one is timevalue .vs. elevation
thanks a lot for any suggestions and help !
Robin May 29, 2006 09:41
Re: how to export x- and y-axis of isosurface ?
To plot the X or Y values, either color your isosurface by X or Y, or create a contour plot of X or Y on your isosurface.
To export the values, go to File>Export, choose your isosurface as the object and pick X and Y as the variables to export (or check the "Export Geometry" button, which will give you the X, Y and Z locations on the isosurface).
Regards, Robin
Tom May 29, 2006 20:34
Thanks a lot Robin !
I do it following your instruction,
For transient problem, i could get the timevalue .vs. Y tStep by tStep (export x y z each tStep), any more easy way to plot t~Y?
Thanks !
Tom May 29, 2006 20:38
hi another help is how to read *.trn file? i tried CFX-post yet cannot , neither cfx-mesh
thanks
Robin May 30, 2006 08:22
In the current release, Post will only read the trn files written before your backup file, full trn file, or associated with the res file at the end of the run. At version 11 you can load arbitrary trn files, but it is up to you to be sure the results belong with your mesh.
Regards, Robin
Tom May 30, 2006 20:29
thanks Robin,
i just want to check the results (just like manipulate *.res in cfx-post) during runing to make sure thinga are ok till the moment, it seems impossible. when cfx11 will release? June?
Robin May 31, 2006 13:19
CFX 11.0 is due in October.
