May 30, 2006, 12:31 |
Creating shared libraries with CFX-10.0
Hi, I'm trying to create a shared library using the cfx5mkext script and Intel Visual Fortran compiler. When I execute the script the fortran compiler starts running but then stops giving the message 'Fatal error, Cannot open MSVCRT'. Can anybody help me? Thanks
May 30, 2006, 13:17 |
Re: Creating shared libraries with CFX-10.0
Dear jorllam,
I understand that the Intel Fortran Compiler is not supported, nor has been test with ANSYS CFX 10.0.. You should contact your help desk, and see if it is worth continuining with your attempts. Opaque PS. The Intel Fortran Compiler will be the supported compiler for ANSYS CFX 11.0.. |
May 30, 2006, 13:25 |
Thanks Opaque,
If the Intel Fortran Compiler is not supported, which fortran compiler should i use? |
May 30, 2006, 13:32 |
Dear jorllam,
You should check the community site, or with your ANSYS CFX help desk.. I recall that Digital/Compaq Visual Fortran 6.5 was the supported compiler.. Opaque. |
May 30, 2006, 16:15 |
OK,
I'll try to get some more info at ANSYS support. Thanks a lot for your help Opaque! |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
how to implement an user defined equation of state in CFX 10.0 | IvanCFD | CFX | 1 | August 16, 2009 08:28 |
Creating patches usinf CFX 4.4 Meshbuild | Kev | CFX | 0 | August 30, 2004 19:39 |
creating expresions in cfx build or cfx post | alex | CFX | 1 | August 22, 2002 13:01 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
