June 5, 2006, 22:59 |
moving mesh
I am looking for algorithm to implement moving mesh in 3 dimensions for internal incompressible flow moving boundary problem. CFX uses a approach for its moving grid option but i couldnt find it.
Specifically, the problem is as follows - The location of all boundary points is known apriori as function of time (user-defined). Before i could go to next timestep, the algorithm should alter/relocate all 'interior' mesh points accordingly. Local refinement of mesh is also not required between timesteps. Thanks in advance |
June 6, 2006, 08:26 |
Re: moving mesh
CFX can handle this. Moving meshes are well documented in the manual. Search for "mesh deformation" and do the FSI tutorial ...
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
How to let the mesh motion solver just solve a small region near a moving boundary? | zhajingjing | OpenFOAM Running, Solving & CFD | 9 | April 28, 2016 04:15 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Waves halted by moving mesh | Piotr Czajko | COMSOL | 1 | November 24, 2007 02:00 |
