-   -   where is the under-ralexation-factor in CFX? (http://www.cfd-online.com/Forums/cfx/22683-where-under-ralexation-factor-cfx.html)
prayskyer June 8, 2006 23:13
IN fluent,there is a under-ralexation-factor,like some expert para,but where can i find the factor in CFX?
Fred June 9, 2006 09:05
Re: where is the under-ralexation-factor in CFX?
The same. Under Expert parameters. Take a look in the online manual.
Robin June 9, 2006 09:20
CFX does not use under-relaxation parameters like Fluent or other segregated solvers do. The timestep provides the necessary relaxation in a physical manner by increasing or decreasing the influence of the transient term.
See the help on monitoring and improving convergence for more information.
-Robin
prayskyer June 9, 2006 09:36
IN CFX,i think the expert parameter means that under-relaxt-factor,before u told me! If so,the expert parameter seems more powerful than that under-relaxt-factor,i must learn them more,
thanks a lot!
Dr. Bian June 9, 2006 10:16
Are u sure of this? It seems the Relaxation Parameters under Expert Parameters are those typical parameters. I never paid attention on these, thought timestep is the only thing. But now, I know more.
Robin June 9, 2006 13:18
The necessity to change these is different because the solvers is completely different. Unless you are specifically directed to change one of these parameters by support, leave them alone.
-Robin
