THERMAL CONDUCTIVITY FOR SOLID DOMAIN -BOUYANCY
Dear all,
I am trying to model a buoyancy problem for a roof composed of various sections. Unfortunately I have not even started because I can not set the following: THERMAL CONDUCTIVITY OF THE SOLID DOMAIN I have selected PURE SUBSTANCE, then CHT SOLIDS, then SOLID (thermodynamic state) and then I input the data, but I can not find where I should input the thermal conductivity of the solid... otherwise it will not run, I guess. another thing is, I would like to run later this model more properly with radiation, but I need also to input the emmissivity of the solid... same case of THERMAL CONDUCTIVITY, I can not find the field to input it. Last, but not least, till now I have not found the molar fraction for the concrete (idealizing this as 'one' solid only... of course in reality it is not that)... but since I wont run a species problem, I think I can override it... e.g use a value of ONE or ZERO... will this cause any problem during the simulation?? Many thanks for your help, whatever it comes is highly appreciated. Regards, Carl |
Re: THERMAL CONDUCTIVITY FOR SOLID DOMAIN -BOUYANC
Molar fraction isnt relevant to the solid states AFAIK.
The thermal conductivity and emmisivity are all set in the material editor. Click the little (+) icons to expand the boxes. |
| All times are GMT -4. The time now is 11:17. |
