how to deal with complex geometry using ICEM?
Old   June 19, 2006, 07:05
Default how to deal with complex geometry using ICEM?
prayskyer
now,i deal with a so complex geometry~ when i mesh it using ICEM,it stop and those come out:
possible error(1) in trim curves for surface F_15040.cut.0.3 (62451) possible error(3) in trim curves for surface F_26815.cut.0.-5 (id=62744)
lots of those come out!
what can i do?and,how to deal with complex geometry?
sincerely
Old   June 19, 2006, 08:14
Default Re: how to deal with complex geometry using ICEM?
myron
Often those messages are benign and don't affect the mesh. If the mesh looks OK - then you're good to go. Make sure you use the Build Diagnostic Topology to remove unnecessary curves and points.
Old   June 19, 2006, 08:31
prayskyer
thanks a lot
sure,after using the Build Diagnostic Topology to remove unnecessary curves and points,but at the beginning of meshing,those "~~~~~"come out,even when it begin to mesh,and it stop running!
need i do some deals to modify my geometry or some others?
Old   June 20, 2006, 07:33
myron
Best bet is to contact your support provider.
heat transfer in an orthotropic material and complex curved geometry zayzan FLUENT 0 October 11, 2011 10:47
ICEM CFD to CFX geometry and mesh Luca CFX 6 February 4, 2010 16:31
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
2D geometry in ICEM NITIN DEWANGAN CFX 3 August 21, 2008 17:25
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
