multi phase simulation
Old   June 26, 2006, 23:18
Default multi phase simulation
Thandavan
hi I am modeling gas solid flow. In pre I am getting the following error.
" Molar mass needs to be set up for Multi Component cases".I am not able to find out the error.
Please help me. Thanks in advance
Old   June 27, 2006, 07:37
Default Re: multi phase simulation
hagupta
Hi Thandavan,
Is your gas a pure gas or a multi-component gas? Do check if the molar mass has been entered for all the components.
Old   June 27, 2006, 22:56
Thandavan
Hi hagupta, I have checked for all the compnents. the molar mass is specified. I donot know, still it persists..
Old   June 28, 2006, 07:36
hagupta
Have u also checked the molar mass option for the "Variable composition mixture" that u have used?
Old   June 28, 2006, 23:29
Thandavan
Hi, for me one fluid is variable composition kixture and the other is reactive mixture. I cannot set molar mass for the variable composition mixture. am i right. But i have set and checked it. still it is not working..
Any idea you have
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 12:12
CFD simulation of Three phase separator tushar393 Main CFD Forum 3 December 22, 2009 22:41
Two Phase simulation help bharath CFX 0 December 1, 2009 09:30
regarding multi phase flows srikanth Main CFD Forum 1 January 26, 2006 02:49
Multi Phase option problem.... Christos Sfyris Siemens 1 May 22, 2003 07:53
