Home > Forums > CFX
CCL for changing the Schmidt number
Old   June 30, 2006, 16:04
Default CCL for changing the Schmidt number
Andrew
Hi, all
I am using following CCL to change the Schmidt number for additional variables. The problem I found is that, for a turbulent flow, a small Schmidt number gave same results as a very big number did. This is not what I expected. Can someone tell the possible reason for this?
Also, whenever I reopen a cfx-pre file, I need redefine the Schmidt number. Is it a bug?
TURBULENT FLUX CLOSURE: Option = Eddy Diffusivity Turbulent Schmidt Number = ### END
Thanks
Andrew
Old   July 3, 2006, 08:54
Default Re: CCL for changing the Schmidt number
V. Kumar
This should not be the case. Please check that the settings in your ccl file are transferred properly to the def file. Examine the .out file from solver to see if the Schmidt number was REALLY different in two extreme cases. For a small Schmidt number your solution should be more diffusive than for a larger Schmidt number.
Settings in CCL file do not overwrite the .cfx (or cfx-pre) file. It only modifies the def file via the following command:
cfx5cmds -def file.def -text file.ccl -write
I donot think that this is a bug.
Old   July 3, 2006, 18:42
Andrew
Thanks,
I have confirmed that my setting in CCL is the same as what shown in .out file. That's why I was curious about the results.
Regards,
Andrew
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 03:17
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Smooth Grid Error! Help seasoul FLUENT 1 March 24, 2008 11:56
Schmidt number col16 CFX 4 March 4, 2008 18:39
