July 3, 2006, 09:26 |
Restart of FSI simulation
Hi all
Can anyone tell me how to restart a FSI simulation under the follwoing situations: 1) Restart from the "transient" solution from ANSYS (with no fsi) as an initial field for the FSI simulations. 2) A normal restart from previously stored FSI data. I know how to make a restart from exisitng CFX solution but not for the case of ANSYS-transient (finite element solution) to MFX computation. Can anyone explain the way to do this with one example each for the above mentioned situations? Or is it not possible in ANSYS10.0 to make above kind(s) of restarts? thanks |
July 3, 2006, 11:48 |
Re: Restart of FSI simulation
What are you using for the FEM calcs? What platform/OS are you running on?
July 3, 2006, 13:12 |
I think I mentioned in my previous mail that I am using ANSYS-CFX10.0 for the FSI coupling using MFX. Operating systems Linux Suse9.0 64-bit AMD and Win-XP Intel 32 bit.
July 20, 2006, 13:23 |
I have viewed your ANSYS .dat file from your old item. You have to insert "save" to your old .dat file.
Then use the following steps 1, run the MFX until it finishes itself 2, insert these command to you .dat file /batch,list resume,ANSYS,db /solu mfrs,2.0 mfti,3 solve save 3, restart MFX Now I am using the same software as you use to solve the FSI problems. I hope we could discuss this MFX program further. |
Restart 2-way FSI with different timestep? | Lance | CFX | 10 | April 17, 2013 00:37 |
2 way FSI simulation errors | ninjabro | CFX | 1 | September 8, 2011 08:23 |
FSI: change material parameters before restart | Lance | CFX | 2 | September 30, 2010 08:38 |
FSI simulation is DEAD SLOW | Lance | CFX | 6 | September 12, 2009 09:00 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
