powder accumulation of gassolid flow in packed bed |
July 3, 2006, 21:37 |
Dear there,
I am modelling a gas-solid flow in a packed bed. the gas-solid flow is introduced into the bed through lateral inlet and powder will be accumulated at the corner of the bed. I am using two fluid method. BUT 1. the convergence is really hard, if compaction parameter of solid pressure force is setting to be over 20. 2. the accumulation zone can not be produced by this model. could anyone (say Nigel - CFX UK) help me out and through this? can kinetic theory simulate the powder accumulation at the corner? should I use non Newton fluid to model the powder accumulation? any suggestions or case example are greatly appreciate. |
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) | balu@gold6 | FLUENT | 4 | July 26, 2012 10:37 |
gas-liquid upflow and downflow in packed bed ,the Ergun pressure drop is same? | W7032654 | FLUENT | 0 | March 11, 2011 21:26 |
Packed bed using euler-euler | akm | FLUENT | 0 | May 28, 2010 05:40 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
Packed Bed Turbulence Model | Erwin Platvoet | Main CFD Forum | 9 | January 18, 1999 00:03 |
