Cn specific heat capacity changes with Temperatur? |
June 26, 2006, 01:23 |
i use a experssion to express specific heat capacity changes with Temperatur(just like gauss distributing),but there is a notice appeared. ****** Notice ****** | | While evaluating Temperature, | | Static Enthalpy on domain hotair | | went outside of its lower limit. Its minimum value was | | -1.1202E+08. The bounds error was handled by extrapolation. | | If this situation persists, consider increasing the table range. i try to changer the table range in the material properities, (intrease the temperature range),but the simulation result seems unreasonable? what shall i do?
June 27, 2006, 09:02 |
Re: Cn specific heat capacity changes with Tempera
This expression, appers alwys when you've to take variable Cp or density depend on pressure and (or ) temperature. If this message disspears afetr a few iterrarions (2 or 3), it will not be a problem, and no influence on your final results Best regards
June 27, 2006, 10:00 |
but in my simulation,the notice didn't disappear, and the result was wrong apparaently. what shall i do?
June 27, 2006, 19:35 |
As the warning says, go back to your fluid property definition and set a reasonable table range.
-Robin |
July 7, 2006, 06:51 |
OH MY GOD ITS SOOOOOOOOOOO HOT
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
