Home > Forums > CFX
calculatiing difference in pressure,dp
Old   July 6, 2006, 05:47
Default calculatiing difference in pressure,dp
ms
Hi all,
I am modelling a sail so have an infintiely thin wall in the middle of my domain (sail). I am trying to export this to a structural solver but I need the difference in pressure, dp across the sail/wall. Is there any way of doing this in CFX before xporting? Otherwise i will have to export the 2 pressure files, and then subtract 1 from the other. To make things worse the meshes are different on both sides of the sail.
Old   July 6, 2006, 07:16
Default Re: calculatiing difference in pressure,dp
Joe
I cant think of a way to do that in Post. Exporting the two XYZ+pressure results sets and then writing your own interpolator would be no more complex than trying to do it in Post (which I dont think could be done anyway.)
Old   July 6, 2006, 09:28
James Date
Another way might be to create your FEA mesh, then read the cdb file into post and let post interpolate onto this FEA mesh. Do this for both sides of the sail, output the data using export and then work out the dp using a simple excel spreadsheet. Since the node pressures on both sides are all in identical locations you don't have to write an interpolation routine.
James
Thread Tools
Trackbacks are On
Periodic Boundary Condition for upwind difference yohey44 Main CFD Forum 0 October 27, 2010 13:10
paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 18:01
the effect of upwind difference hades Main CFD Forum 8 March 15, 2009 00:43
Difference between scaled residuals and... Dieter FLUENT 0 April 28, 2006 17:52
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
