boundary layer, very urgent
Old   July 18, 2006, 03:33
Default boundary layer, very urgent
nicolas
Hi. I am a beginner in CFD. I use ICEM CFD 10.0+ cfx 5.7.1
I have a cylinder+ some others parts of a engine. I used blocking + hexa mesh for everything under ICEM. I used O grid generation, and I created a small volume around the wall, to set a fine mesh here. Someone told me that , with hexa mesh, I did'nt have to care about the boundary layer(but i need to have a fine meshin this volume). What i understood, is that I don't care about the position of the first node, and the law mesh in this volume.
Is it right? wrong? I found no explanation on websites, documentations, on "how to" do a boundary layer when using hexa mesh (i found it for prism, tet)... Do I need to set exponential law in the small volume around the wall(and how to do it?)
Does someone can help me to understand how to treat the boundary layer under icem, using hexa mesh (and o grid generation).
If it is explained on doumentation, can you give me the references ?
Regards, Nicolas.
Old   July 18, 2006, 05:46
Default Re: boundary layer, very urgent
Kramer
Which kind of turbulence model do you want to use :
k-epsilon, k-omega, SST, or something else?
SST for example needs an y+ value of approx 1 (=>very small first element on the surface). So you will need a fine mesh in the boundary layer and at least 15 hexa elements in the boundary layer.
Old   July 18, 2006, 06:00
nicolas
I use SST.
To know the distance, where i need to set the 1st node(if i choose y+=1),I need to know the Reynolds number? In a certain way, i need to know the solution, before being able to create a good meshing for the boundary layer?
other question: do you you know how to fix the distance between the wall and the 1st node, and, in the same time, set a expansion law (i have found how to set the expansion law, but i can't fix the distance). I use icem
thanks, nicolas
Old   July 18, 2006, 06:36
Kramer
You have to make a good guess for your first node distance, its depending on the flow situation (estimate Reynolds number...)
For example: i have simulated the flow around an airfoil with SST an had to set the first node at 0.01 mm to get y+ <= 1.
Seconde question: there is an overall option to set the distance for the first node generally (settings an so on..., i dont remember exactly where), but independent from that you can use the spacing function (right there where u define expansion law) to set the value
Old   July 18, 2006, 08:52
Joe
Read the section in the turbulence modelling section entitled something like "Advice on near wall meshing".
Old   July 18, 2006, 09:58
imad
Dear Nicolas under blocking you find pre-mesh params select them and use edge params to select the edge near the wall and define the distance for the first and last point and if you want the mesh law
Old   July 18, 2006, 10:23
nicolas
Dear imad, i already try this. but i dont understand how it works. to set the distance from wall to node ->i sould use the values called in the software "spacing 1" and "spacing 2" ?? thanks for your reply. Regards, Nicolas
Old   July 18, 2006, 13:55
imad
DEAR Nicolas when you select the edge An arow appear, his direction define the first and the last point if you put a value and the distribution don't change, you should select copy to parallel edge or update mesh with best regards Imad
Old   July 18, 2006, 14:00
imad
yes spacing 1 is the first distance of edge and spacing 2 is the last but th direction of edge is the direction of arow
Old   July 18, 2006, 22:52
hi Kramer,
SST does not require y+ approx =1. Using the automatic wall function approach it can switch between full boundary layer modelling (around y+=1) to wall function modelling (y+>11) and blend between.
You should ask yourself whether the boundary layer needs to be modelled directly or if a wall function approach is OK. Then you generate a mesh with y+=1 or >11 based on that decision.
regards, Glenn
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 14:11
3D Boundary Layer Mario FLUENT 0 February 17, 2009 03:40
urgent: 2d laminar boundary layer simulation Abhishek Main CFD Forum 2 August 1, 2006 19:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
