July 25, 2006, 07:31 |
Free surface problem
Hi, I have got problem with modelling rotating cylinder filled with water. There is an air above the water so it is free surface problem. I set geometry with two cylinders (meeting). Top cylinder is set to be initially full of air and bottom cylinder has water only. They are rotating with equal rotational rate. I set an interface between them and have a problem with solving. Solver gives such a message:
*** INSUFFICIENT MEMORY ALLOCATED *** Error detected by routine MAKDAT CDANAM = ACS CDTYPE = REAL ISIZE = 4017008 Can anyone give some advice how to set initial conditions or other spects of the case? I would be very gratefull. Luk |
July 26, 2006, 09:42 |
Re: Free surface problem
Try increasing the solver memory allocation factor in the solver manager before running your solution. It's in the help doc if you don't know where to set it.
July 27, 2006, 01:07 |
Sir, Thanks for Your help. Actually, I solved the problem leaving one disc filled with water/air with use of step function for initiation but I am still interested in solving it previously described way.
Luk |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
CFX convergence issues with free surface | adenlan | CFX | 3 | September 2, 2011 06:43 |
Linear analytical solution oto the 2D free sloshing water surface elevation | bearcat | Main CFD Forum | 7 | August 5, 2011 20:13 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
