Home > Forums > CFX
Data reader : Timestep List
Old   August 3, 2006, 13:59
Default Data reader : Timestep List
Felix
Hi everyone,
I need a little help on CFX 10.0 session files. I have 15 result files from a transient calculation and want to automate the post-processing. Want I want to do is to run a post-processing macro (an existing session file) in all the 15 files and I thought about doing it using a FOR loop.
The problem I have is I am not able to retrieve the different timesteps and load the associated results. Here is the command line I use:
! $TimeStep = (getValue("DATA READER", "Timestep List"));
Using this, "TimeStep" seems to be only one string element containing the correct list (I printed it in a file). But I cannot extract only one element from that list to use it and thus everything that is not TimeStep[0], the list, is empty. How sould I do it? Also, is there a way to know the number of elements in that list i.e. length(TimeStep) or something similar ?
Thanks a lot, Felix
Old   August 7, 2006, 06:41
Default Re: Data reader : Timestep List
Johnson
Hi Felix,
You need to use a bit of Perl to chop up the string and put it into an array. Something like the following should work.
Regards,
Johnson
# Load a transient file and read the time step list
> load filename=myFile.res
!$timestepList = getValue("DATA READER", "Timestep List");
!@timesteps = split(/, /, $timestepList );
# Print time value and pressure for each time step
! open(FH,">myOut");
! foreach $ts ( @timesteps ) {
> load timestep=$ts
! $val = ave("Pressure", "Point 1");
! $time = getValue( "DATA READER", "Current Timevalue");
! print FH "$time $val\n";
Old   August 7, 2006, 11:48
Felix
Thanks Johnson, it works well
Felix
Thread Tools
Trackbacks are On
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
write a xy data file every timestep pieter brodeoux FLUENT 1 December 5, 2007 18:30
XYZ (ASCII format) data points into GAMBIT Neil FLUENT 1 August 7, 2007 09:24
How to store transient data with various timestep? Oliver CFX 4 December 18, 2005 20:56
